where do I pour transmission fluid. I cannot find it. I find water, brake, coolant, steering but no transmission fluid.
Dec 4, 2008 at 1:26 PM
✓Experienced Mechanic
Hi:
I assume it has an automatic trans. Trans fluid is added directly into the trans dip stick tube. It's the tube that holds the dip stick. You will need a small funnel and make sure that it can get air between the tube and the funnel otherwise it will burp it back up.
