2002 Chrysler PT Cruiser car stutters and just shuts off no
71,000 MILES • 4 CYL • FWD • AUTOMATIC
COCO5234
i've havd this car since feb.2010,i've had major problems big time lemon i bought it as-is from maroone first tranmission,then back-end problem then problem with something that controls the brakes went bad and i had to replace the entire rear brakes,then the cooling system then the container that holds the coolant went bad,,so now i don't have the money to get it fix i took got it on computer and it showed nothing i really need help i bought this for my daughter she cant drive it .
thanks
Jul 15, 2010 at 12:35 AM
APALOMO01
  • 17 POSTS
I've had my pt since 2002, i've been through it all to tell you the truth. If you could give me a bit more info I can try and help you narrow it down. The first few things that come to mind would be a clogged or dirty fuel filter due to bad gas (bigger problem since it's inside the fuel tank itself). One problem I had was also the PVC valve, the car would stutter at times and then come to high idle off and on when I stopped and would the engine would cut off suddenly. This was an air intake/vaccuum leak problem, usually you can hear it hissing off and on under the hood when the car is on. Other than those first few suggestions, when the car was running rough it had been a while since a tune up. When it was really bad on acceleration and when coming to a stop, I found out a spark plug was tightened to much and fractured which created a misfire and occassionally shut the car off. Do you have any check engine lights? Let me know. Anthony
Jul 16, 2010 at 6:12 PM
COCO5234
no check engine light comes on at all ,car has new spark plugs no hissing noise either i really don't no what to do i can't believe this car is like a demon.
thanks, Diana
Jul 17, 2010 at 11:47 PM
