2002 Chrysler PT Cruiser camshaft position sensor
OCMELI2420
Computer problem
2002 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic
My 2002 Pt Cruiser check engine light is on. It sputters when I try to speed up. I did a self diagnostic and it came up with code 0340. I found that it means camshaft sensor problem. i replaced it and it still wont start.
Jun 18, 2010 at 2:47 AM
  • 75,988 POSTS
If the fuel pressure is correct and injectors are pulsing-check and test the following
power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 18, 2010 at 9:01 PM
