2002 Chrysler PT Cruiser Battery Replacement
65,545 MILES • 4 CYL • 2WD • AUTOMATIC
RPAPAT
I am trying to replace the battery. It appears that the air filter box needs to be removed to get to the battery hold down and remove the battery. How do I remove the air filter box? I can't see any screws holding it down, but it will not release.
Dec 7, 2008 at 7:11 AM
  • 110,248 POSTS
Hi:
Check from the inner fender if there is a bolt holding it, or it may just be sitting snapped into place. If you remove the air filter, can you see any evidence of bolts?
Dec 9, 2008 at 5:42 AM
