2001 Chrysler PT Cruiser Wont Start randomly
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
CJ68
Hi there!
Randomly when you go to turn the key nothing happens. At this point only jump starting it will work.
Steps taken
Replaced the battery 5 months ago... load tested the battery ok
Checked the voltage when car is running over
14 volts (means alternator is charging)
Replaced the starter
Could run for a few days then randomly not start.
Please help..starting to go insane...
Nov 1, 2010 at 4:03 PM
  • 75,988 POSTS
Inspect and test the starter relay and the ignition switch.
Dec 20, 2016 at 9:53 AM
CJ68
Thank you for responding. I forgot to tell you before I did swap the relays around the starter & the horn relay since they both had the same number stamped on them. I will take the instrument bezel off now to check the starter switch. How do i do this, am i checking voltage when the switch is in the on position. (12v) ?
Thank you again
