2001 Chrysler PT Cruiser Timing Issues
91,500 MILES • 4 CYL • 2WD • MANUAL
SHERMAN48
I just replaced the timing belt on my 01 Pt cruiser and now I have a fault code on the computer. I had the code read and it is for engine running too rich. Now is this the timing or are there other things I should check before I ripe the whole car apart again to retime it?
Apr 23, 2009 at 1:17 AM
  • 75,988 POSTS
Rich condition:
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Apr 23, 2009 at 1:28 AM
