2001 Chrysler PT Cruiser Thunking when turning to the right
10,000 MILES • 4 CYL • 2WD • AUTOMATIC
MESHAD
Took my PT in today for a constant thumping I can hear and feel in the gas pedal coming from the right tire it seems worse at speeds of 20+mph. Mechanic said it was the tie rod so I replaced it but that only seemed to make it worse. Also relaced front tires. Now there is a cracking sound as if something is perhaps hitting metal on metal when going over bumps. Trying to keep my car safe and not go broke doing it. Any ideas would be great.
Thank you!
Apr 1, 2009 at 6:31 PM
BMRFIXIT
  • 19,053 POSTS
Recheck tie rod ends suspect stabilizer links and lower control arm bushings
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_286.jpg
Apr 1, 2009 at 10:46 PM
MESHAD
I am on my way back to the shop in hopes I am now armed with enough info to get the job fixed correctly and entirely. This is my first time using this service and if it works out you can bet I will be back and advise my friends about the site.
Again I really appreciate your help and have a great day!
Mesha
Apr 2, 2009 at 3:45 AM
