2001 Chrysler PT Cruiser Stated running hot.
2001 CHRYSLER PT CRUISER
67,000 MILES • 4 CYL • 2WD • AUTOMATIC
CELHR
just started running hot. local repair shop changed thermostat, radiator cap, flushed system and replaced anti-freeze. When I picked it up, i had to return because it ran hot down the road. The repair shop believes it now a broken head gasket. Their bill will be 141.00 gasket kit, regrind head 8 hour labor for a total cost of 767.00. your opinion please.
Charles
Jul 30, 2008 at 11:54 AM
BLACKOP555
  • 10,386 POSTS
first i will say is thats a good price for a headgasket replace.
next i will say before doing that i would make sure its bad.
buy a cheap compression tester and check the cylinders, they all low/ one lower then the rest?
add a squirt of oil then redo the compression does the compression still stay low? or get better.
if it stays low suspect headgasket. if all is good headgasket isnt bad.
Jul 30, 2008 at 3:10 PM
C_NAVARRETE
autozone carries a bottle of head gasket sealer I'd try that before anything else it's worked on all the cars I've used it on it's a lime green bottle I can't remember the name of it right off the top of my head sorry .
Aug 6, 2008 at 5:55 AM
BLACKOP555
  • 10,386 POSTS
if the heads need reground chances are that wont work, but if its a simple tear or puncture then that stuff is a temporary fix.
Aug 6, 2008 at 12:16 PM
