2001 Chrysler PT Cruiser Spark plugs
BALEAHAY
  • 2001 CHRYSLER PT CRUISER
  • 4 CYL
  • FWD
  • 49,000 MILES
Are the spark plugs easy to do on your own? Or is it best to go to a shop. How complicated is it. GB
Tuesday, February 10th, 2009 AT 6:59 PM
ZACKMAN
  • 4,202 POSTS
Not that complicated. If you can turn a wrench and follow instruction, you can do it.
The Intake Manifold has 5 (8mm) bolts at the front, and 2-3 (13mm) bolts at the back (depending on the year) - holding it to a bracket. Remove them all. Lift the manifold off - do not drop the seals down the manifold. Lay a towel over the manifold. Hang the manifold from the hood with a bungee (to keep it out of the way.) Now you can get to your plugs and wires. You will need a 6 inch extension and a 5/8 deep socket to remove plugs.
Sunday, February 22nd, 2009 AT 1:42 PM
