2001 Chrysler PT Cruiser pulls to left then to right
2001 CHRYSLER PT CRUISER
80,000 MILES • 4 CYL • FWD • AUTOMATIC
FIRSTIMEOWNER01
hello just bought my first pt and when i test drove it it was pulling to the left abit they did a front end allign and found bad ball joint and tirod they replaced it then it started to pull to the right they checked the specs on allign and rotated tires then replace 2 of them well it didnt seem to be any better the then replaced the rotors on front and re ground the drums on back balanced all the tires etc... it is still pulling when i apply the breaks intermittenly to the right. is it possible I have a calaper problem or what thankyou in advance ......first time buyer
Sep 29, 2009 at 6:46 PM
BMRFIXIT
  • 19,053 POSTS
As you travel on a smooth straight road do you need to constantly correct the steering, for it to go straight !and if so its an alignment and front end issue
if it goes straight but if you tough the brakes pulls to one side suspect brake issue check calipers and hoses
good luck
Sep 29, 2009 at 11:04 PM
