2001 Chrysler PT Cruiser Power windows
2001 CHRYSLER PT CRUISER
109,400 MILES • 4 CYL • FWD • AUTOMATIC
JKMPOST
The car rear window switches on dash work fine. The 2 front window switches are automatic down. Neither front window will go down and I don't the motors when I hit the switches, but when I hit the switches on either front windows to roll them up you can hear the motor receive power on that side door. The windows are in the up position. I have checked with the parts supplier and the cluster is available as a switch/relay. Could the relay in the switch cluster be the problem.
Feb 17, 2009 at 6:15 PM
  • 110,194 POSTS
It could be the relay. You need to check the switch to make sure it isn't bad too.
Feb 24, 2009 at 7:28 AM
