2001 Chrysler PT Cruiser power steering
79 MILES • 4 CYL • 2WD • AUTOMATIC
CANDIEIRO1077
My engine light is on. I went to Auto Zone to check it out, and they told me that the power steering pressure sensor needs to be replaced. my question is where is that sensor located?. i need more information about it please if you would.
Mar 10, 2009 at 12:39 PM
DOCFIXIT
  • 18,828 POSTS
On the rack will have to get from under car. find the power steering pump. There will be two lines (hoses) coming from the pump. One will be just a hose with a clamp holding it (this is the return line) the other one will be a heavy duty hose and pipe (this is the high pressure hose). Follow this one till you see a sensor screwed into a fitting that is part of the pipe. That is the pressure switch.
Mar 11, 2009 at 3:52 AM
