the pt is blowing antifreeze out the top of the radiator when adding coolant. why?
Feb 4, 2010 at 6:37 AM
✓Experienced Mechanic
If it is blowing it out when the engine is cool, chances are you have a bad head gasket. Have the compression tested to see if there is low compression in one.
