I have a 2001 PT Cruiser. I have flushed change radiator cap, thermostat. The water pump does not make any noise or leak. I have 101,200 miles the car does cut out a miss when I accelerate.
Can the timing belt need to be replace which may be causing the water pump not to turn quick enough and can that also be causing to car to miss. I also had this problem late last Summer but once the temperature became under 85 degree's it was OK. Now that the Air Temperature is getting 85 degrees it is starting to over heat. Also the engine miss is worst at acceleration.
Apr 25, 2009 at 3:47 PM
