2001 Chrysler PT Cruiser Noise that comes and goes
108,000 MILES • 4 CYL • FWD • AUTOMATIC
SBEARDSLEY00
I have a PT that makes a humming or rubbing noise. Sounds like it's coming from the rear. When the car is turned on it takes a while before I hear it, 8-10 miles. It stops when I hit the breaks, but usually starts again, it comes and goes. It can be a low back ground noise or can get very loud. Can be loud outside of the car. It's worse when it's damp or wet. When the car is turned off and turned right back on it does't always start back. I've had the breaks torn apart twice and they do find even ware, but say I don't need breaks yet.
Aug 9, 2009 at 11:53 AM
  • 110,248 POSTS
Does the sound change when turning? Does it change with vehicle speed?
Aug 15, 2009 at 2:57 PM
SBEARDSLEY00
Speed or turning don't seem to make a difference.
Aug 15, 2009 at 11:07 PM
  • 110,248 POSTS
If it is a humming sound, either it is a bad wheel bearing or could the sound be coming from the fuel tank area? The fuel pump may be making noise.
Aug 16, 2009 at 1:15 PM
