2001 Chrysler PT Cruiser Idle Speed Air Control
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
COLONEL RAY HENSON
Hello, I did the code look up and the code said
The Idle Speed Control Motor doen't seem to be working properly
what do i need to do
also i just put in the controll for all the cooling fans cost with labor $760.00
is that relevant to this?
Thanks
Dec 6, 2008 at 6:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello I don't believe the previous fan repairs would have anything to do with this, unless the mechanic who serviced the vehicle accidentally unplugged or in some manner harmed the wiring of the IAC. You should test all of the wiring to the IAC motor. Perform the following procedures and post your results. I will follow up.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_15.jpg
FIGURE 2
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_14.jpg
Dec 6, 2008 at 7:22 PM
