2001 Chrysler PT Cruiser help
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
PELONLOCO
i change the timing belt and i drive it for a hour and did good then i try to drive it and it will not change the gears it will stay on first gear only
Aug 18, 2010 at 12:27 PM
ERNEST CLARK
  • 1,730 POSTS
With so many miles on your car, it's possible the tranny was ready to go anyway. Chrysler transmissions are notorious for failing right at 100,000 miles.
First double check all of your sensors/wires/connectors to make sure they're not loose or disconnected. If your computer is reading a faulty signal, it'll prevent your engine from shifting.
Next have your computer scanned with a scanner capable of reading transmission codes.
Sep 17, 2010 at 12:16 AM
