with a 2.4 l engine, auto trans the engine died while coming to a stop. then it will not crank. checked starter with remote, it cranked. checked starter relay, ok. jumpered from remote battery post to terminal 87 in pdc with relay out, starter operates. replaced ignition switch. still no starter operation with key. all lights and horn, windows work. no dtc's either. thank you *** Also no fuel pump running sound when key is turned to run position.. thanks
Jan 10, 2010 at 9:43 AM
