drain plug location
2001 CHRYSLER PT CRUISER
BADAZZDAWG47
Four cylinder two wheel drive automatic 65,000 miles.
Where is the antifreeze drain plug located on this car?
Jan 8, 2010 at 9:33 AM
ERNEST CLARK
  • 1,730 POSTS
Your drain plug is located at the very bottom of the radiator, towards the drivers side of the vehicle and on the engine side of the radiator.
Note:
Do not use pliers to turn the drain plug. Use your fingers only.
Position a clean collecting container under drain-cock location.
Without removing the pressure cap and with system not under pressure, turn drain-cock counterclockwise to open.
The coolant reserve bottle should empty first, then remove the pressure cap.
If coolant reserve bottle does not empty first:
Check condition of the pressure cap and cap seals.
Check for kinked/torn overflow hose from filler neck to reserve bottle.
Allow cooling system to drain completely.
If I have helped you, please take the time to vote for me, as my reputation pays my bills.
Feb 12, 2010 at 11:46 PM
