I dont think its the distributor cap, one thing to check, make sure no two spark plug wires that are right next to eachother in the firing order are running parrallel or youll get crossfire.
Next step is to check for spark on that cylinder and compare it with the rest, if its good then the ignition isnt to blame.
Check the compression and fuel in that cylinder.
SPONSORED LINKS
Monday, August 25th, 2008 AT 8:06 PM
