2001 Chrysler PT Cruiser Air bag light stays on
120,000 MILES • 4 CYL • FWD • AUTOMATIC
AJPATTI
The air bag light is on and the fault code refers to the seat belt tensioner. The code was reset but the light comes back on. What needs to be fixed and how.
thanks
Tony
Feb 22, 2009 at 2:47 AM
DOCHAGERTY
  • 9,606 POSTS
If the fault is for a failed seat belt tensioner, then replacement of the failed tensioner assembly would seem to be in order. Has that been done? If it has and the fault is still present, then the wiring is suspect. The supplemental restraint systems used on most cars are quite sensitive to faults such as resistance fluctuations due to corrosion or a poor connection. These systems are designed to be this way and it can set a fault for a very small deviation, less than one Ohm will set a fault.
Feb 22, 2009 at 2:58 AM
