2001 Chrysler PT Cruiser 2001 PT Cruiser over heat when idi
LUIGI619
  • 2001 CHRYSLER PT CRUISER
  • 4 CYL
  • 113,893 MILES
I have tested and checked everything with radiator fan. the fan turns on when direct power from battery but will not turn on when connected to wire harnes to relay. all relays and fuses fine, when disconnnected wire connectors little burn mark on connector wire. should i connect fan straight to battery or change wire from relay box. what else can it be any suggestions.
http://www.2carpros.com/forum/automotive_pictures/453252_harness_1.jpg
Thursday, December 24th, 2009 AT 2:01 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Have you tried jumping power at relay to turn fan on.
Also is engine light on? If so possibility Coolant Temp Sensor is Bad.
Thursday, December 24th, 2009 AT 2:22 PM
LUIGI619
Whats the best way to jump from realy.
Friday, December 25th, 2009 AT 9:55 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, on the Low Speed Fan Relay locate the Socket with a Dark Green wire and the find a power source jump from the power source to the Dark Green wire.
https://www.2carpros.com/forum/automotive_pictures/188069_01ptcruisercoolfan_1.jpg
Saturday, December 26th, 2009 AT 7:49 AM
