2001 Chrysler PT Cruiser
76,255 MILES • 4 CYL • 2WD • AUTOMATIC
LATIN126
i have a 01 pt cruiser looks aand runs great but will n ot shift from low gear.i had a obd test and codes p0605 and po700 came up. what is this and how can i make this car better?
Oct 21, 2009 at 11:59 AM
BMRFIXIT
  • 19,053 POSTS
TCM failure
clear codes and recheck if code return
check as follow
engine ground connection
TCM grounds
TCM battery feed and fuses
TCM fused ignition switch output circuit
Power feed to transmission Relay
replace TCM
Oct 21, 2009 at 1:31 PM
