2001 Chrysler PT Cruiser
2001 CHRYSLER PT CRUISER
SANDRA3314
Noises problem
2001 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic 156K miles
Hi again, i'm totally clueless on what is happening with my car. For the last 4 months everytime it rains my pt cruiser "squeels" it's so weird it's driving me crazy! Would anyone have an idea? could it ve the belts? any input would be appreciated. thanks
Apr 2, 2009 at 11:49 AM
CARADIODOC
  • 34,381 POSTS
Belts are the likely cause. V-belts can wear and become loose. Serpentine belts are usually tightened with a spring-loaded tensioner. Unless it's weak, belt tension is not common, but pulley alignment problems are. The most common alignment issue is a worn pivot in the spring-loaded tesnsioner.
When it's not raining, try sprinkling a little water on the belts while the engine is running. If the squealing starts, you found it.
caradiodoc
Apr 2, 2009 at 4:19 PM
