2001 Chrysler PT Cruiser
GALLEGAMEL
2001 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic
What is a sol pack?
Is it possible to fix the timing belt ourselves?
Nov 19, 2008 at 10:14 AM
ZACKMAN
  • 4,202 POSTS
Sol pack is solenoid pack controlling your transmission shifting.
Change your timing belt yourself? It is possible, if you are familiar with automotive maintenance and repair. But if you are not, I recommend going to a technician more familiar with the job. There are many things that can go wrong if you are not careful. While you are doing your timing belt, you will want to replace your water pump.
Nov 19, 2008 at 11:54 AM
