2006 Chrysler Pacifica tailgate lock won't open
33,500 MILES • 6 CYL • FWD • AUTOMATIC
LINDWOOD43
Auto lock on tailgate will not open,The auto lock opens all the doors but will only produce a click on the tailgate. Is there a simple owners manual fix i'm missing. I use the drivers auto lock and the key auto lock. They both only produce a click in the tailgate. Is the lock system broken/ What type of repair is needed and what is an estimated cost
Oct 23, 2009 at 12:59 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation
If you can hear a click then the actuating solenoid is working, so i would be removing the trim, an having a look at what is actually going on, it jut may be that the link rod has come off, theres are usually attached by a plastic clip and it may have parted way.
mark (mhpautos)
Oct 23, 2009 at 2:21 PM
