2006 Chrysler Pacifica 2006 pacifica
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
GBEACH
radiator cooling fans are coming on like 5 seconds after you start the car, even when it is cold and they
are not shutting off. Thought they were just coming on when the a/c was on, now there coming on when the a/c is off, and never shut off. it is a 3.5 liter. could it be thermostat, coolant temp sensor?
Jun 30, 2008 at 4:34 AM
  • 110,251 POSTS
Hi:
It could be the temp sensor or a bad fan relay. Switch out the relay with another one that is the same to see if that is the problem.
Mar 19, 2009 at 3:33 AM
