I have change the thermostat on the it and still runing hot. Check the radiator hose it was swollen. Is the thermostat bad
Aug 15, 2010 at 2:37 PM
✓Experienced Mechanic
Test the thermostat and also check if the hose is collasped internally blocking off coolant flow
Aug 15, 2010 at 2:39 PM
I just gave you something to work with I'm not done with you however you choose to give me a negative feedback,you came here with nothing you're leaving with nothing.If you have some patience maybe you'll get some answers from us experts in here.Have a nice day and good luck!!!!BTW-thank you very much for your feedback-it only makes me think about people like you...The world is not a perfect place...
Aug 15, 2010 at 3:03 PM
TOMP1964
MEMBER
Mr rasmataz i am new to this and you prejudge me..
[quote:4d90249aee="rasmataz"]I just gave you something to work with I'm not done with you however you choose to give me a negative feedback,you came here with nothing you're leaving with nothing.If you have some patience maybe you'll get some answers from us experts in here.Have a nice day and good luck!!!!BTW-thank you very much for your feedback-it only makes me think about people like you...The world is not a perfect place...[/quote:4d90249aee]
Aug 15, 2010 at 3:09 PM
Who gave the negative feedback it sure ain't me, now who's prejudging-just put it behind you, and I'll move on and help the others that needed the most bcuz I don't need this kind of stuffs, You just didn't give me a chance to fix your problem, Aloha!
