2005 Chrysler Pacifica Oil light
68,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALISON22
I recently had my oil changed and I have every 3000 miles. My oil lightcomes on when I start the car. Not evertime but most of the time. If I turn it off and start it again it goes out. Do I have a major problem? Also the ABS light stays on but the dealer said it was fine as liong as it does not blink is that ok?
thanks
Mar 24, 2010 at 1:59 PM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings/sludges
For the ABS light its not suppose to come On-it wasn't like that when you 1st bought it-Have them check it-
Mar 24, 2010 at 2:05 PM
