Just recently the engine light came on. It registered code 0420, stating that the right bank o2 limits are incorrect. What is the usual cause of this? Several mechanics have said that replacing the o2 sensors will not correct it and doubt it is the catalyic converter. What is the MOST LIKELY cause? I know you can troubleshoot from a desk, but in your experience, what is really the problem? The engine uses about 1 qt of oil every 1500-2000 miles. Been doing that since I bought it with 20,000 miles on it.
Also, what is the interval for replacing the timing belt? There is no mention of it in the owners manual and the maintenance guide only goes up to 100,000 miles.
Thanks,
Bob
Thanks,
Bob
Dec 3, 2009 at 5:03 AM
