2005 Chrysler Pacifica Driver side controls
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOYLEJOB
All of a sudden all of the electric contols on the driver side door have stopped working. None of the controls on the driver side door are working (mirrow, locks, seats, windows). Controls on the other doors are working. Can press the lock button on the passenger side door and all doors will lock except the driver's door. Remote will not lock or unlock the doors. Controls worked fine earlier in the day.
Any ideas on what might cause this? I have had this care for about 2 years. It was bought at a car auction and has been a wonderful vehicle. I do not have an owners manual so I was not able to see if maybe this was a fuse related issue or something else simple like that.
Dec 6, 2008 at 11:57 AM
GEORGE DOE
  • 10 POSTS
Your car has a fuse under the hood called driver door node . This fuse is probably blown . If it happens again this can be caused by the wires in the 'a' post shorting when the door is opened or closed
Dec 14, 2008 at 12:57 PM
