2005 Chrysler Pacifica
ARABIANCHAI1
Engine Performance problem
2005 Chrysler Pacifica Four Wheel Drive Automatic 50000 miles
i put diesel gas in my Chrysler pacifica by mistake,now it doesn't want to turn on.alot of smoke coming out of the muffler.
Oct 18, 2008 at 7:11 AM
  • 110,248 POSTS
You need to drain the tank, replace the fuel filter, blow out the lines, and clean the fuel rails. I would also recommend a fuel injector cleaner when it is running again. The smoke is because the engine is trying to burn oil.
Mar 18, 2009 at 6:40 AM
