2004 Chrysler Pacifica Vents will not change properly
101,000 MILES • 6 CYL • AWD • AUTOMATIC
TWILLIS
I am curious what to look for if the vents will not change properly on my vehicle. It has the dual climate control system. I will not change from floor, to defrost, to vents. System is blowing fine but seems to only blow into floor.
Dec 29, 2008 at 12:11 PM
  • 110,248 POSTS
Hi:
I believe the system is actuated by vacuum from the engine. Look and listen for leaks under the dash, and check under the hood for leaks too.
Let me know what you find.
Mar 18, 2009 at 6:27 AM
