2004 Chrysler Pacifica oil valve leak
98,500 MILES • 6 CYL • 2WD • AUTOMATIC
HKOON
my pacifica has been leaking oil for about 25000 miles now. I had the valve gasket cover replaced because that is where the leak was coming from. the mechanic who fixed it said that it didn't look like the old one should be leaking but he put the new one on anyway. the oil leak never stopped and it is still coming from the same valve. what could i possibly do to get this oil leak fixed????
Aug 11, 2008 at 10:16 AM
  • 110,248 POSTS
If the mechanic said the old one looked ok, and the new one didn't chance the problem, I think you need to check the engine for a different leak. let me know what you find. (check intake)
Mar 19, 2009 at 3:10 AM
