Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Pacifica
Interior
Dashboard
2004 Chrysler Pacifica Leaking water
2004 CHRYSLER PACIFICA
82,000 MILES • 6 CYL • FWD • AUTOMATIC
DIANAMULLINS
MEMBER
1 POST
I have a 2004 Pacifica and when it rains heavily and the car is parked water has begun to leak under the passenger side of the dash from a black box
Feb 7, 2010 at 3:16 AM
ERNEST CLARK
Experienced Mechanic
You have an "Cabin Air Filter" that's located on the cowl at the base of your windshield. (outside)
Most likely the molding around the box has gone bad. But you could also have a crack in the plastic itself.
Remove the vented cover and check the molding. If this checks out, remove the filter and look inside with a flashlight and try locating a crack.
Mar 1, 2010 at 10:17 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
