2004 Chrysler Pacifica Leaking water
82,000 MILES • 6 CYL • FWD • AUTOMATIC
DIANAMULLINS
I have a 2004 Pacifica and when it rains heavily and the car is parked water has begun to leak under the passenger side of the dash from a black box
Feb 7, 2010 at 3:16 AM
ERNEST CLARK
  • 1,730 POSTS
You have an "Cabin Air Filter" that's located on the cowl at the base of your windshield. (outside)
Most likely the molding around the box has gone bad. But you could also have a crack in the plastic itself.
Remove the vented cover and check the molding. If this checks out, remove the filter and look inside with a flashlight and try locating a crack.
Mar 1, 2010 at 10:17 PM
