2004 Chrysler Pacifica How to change rear brake pads?
80,000 MILES • 6 CYL • AWD • AUTOMATIC
CRRARROYO
I have chrysler pacifica that needs rear brakes replaced but for some reason i cant take off the caliper i took off the tow bolts that hold it top and bottom, there is something that is holding at the midle because i can move back and fowrd at top and bottom. i changed the front ones new pads and disk and only took me about 45 to 55 min. if any one can help me id apreciate it. thanks in advance.
Jun 27, 2008 at 1:46 PM
MASTERTECHTIM
  • 4,750 POSTS
try using a c clamp to compress the piston in the center of the caliper to make it easier to pull off.
Jun 27, 2008 at 1:53 PM
