i can hear ac kick on in the engine but fan is not turning on. wondering if its the relay and if so where is it located
Jul 28, 2019 at 4:36 AM
(Merged)
GARYS712
MEMBER
Check fuse panel under hood on driver's side. You can also try to unhook negative terminal from battery and then hook back up after a minute or so. Things might reset then.
(Merged)
VIKTORIA
MEMBER
1 POST
what fuses should i check for my air conditioner
(Merged)
✓Experienced Mechanic
the fuse is in the power disrubution center.. also check this page.
