2004 Chrysler Pacifica code P0344
WIS298
Engine Mechanical problem
2004 Chrysler Pacifica 6 cyl Front Wheel Drive Automatic
car died while driving code P0344 replaced cam shaft sensor still will not start acts like no fire what do i need to do to fix this .any ideas will be helpfull
Dec 14, 2009 at 7:04 PM
  • 31,937 POSTS
Hi there, as you say this is a cam position sensor, with the new sensor in place and still a problem, i would be checking the loom back to the ECU plug for continuity in the CPS circuit.
Mark (mhpautos)
Dec 14, 2009 at 7:26 PM
