2004 Chrysler Pacifica Check engine light - oil sending uni
60,600 MILES • 6 CYL • AWD • AUTOMATIC
HOOHOOHAA13
Check engine light (not oil light) went on, had it checked. Tech found a few things, 1 he said was oil sending unit. To replace it, he is figuring 2 hours at $85/hr, $170 total, plus cost of part ($30) and oil change. Different tech, different place said it would be 47.70 for the part and to install it,plus cost of oil change. Which sounds more accurate for replacing an oil sending unit?
Jan 28, 2009 at 7:20 AM
  • 110,248 POSTS
Labor is 0.7 hours and the parts around 30.00. It sounds like you are being over charged.
Mar 18, 2009 at 4:38 AM
