2004 Chrysler Pacifica BACK WIPER AND INTERIOR LIGHTS
131,690 MILES • 6 CYL • AWD • AUTOMATIC
THINLEY
HELLO, MY CAR'S FRONT WIPERS ARE WORKING FINE BUT THE BACK WIPER IS NOT MOVING. WHEN A FRIEND TRIED TO FIX IT THINKING IT'S A FUSE PROBLEM, I GUESS HE MESSED WITH THE WRONG ONE AND NOW THE SMALL INTERIORS LIGHTS (THE ONES THAT ARE ABOVE OUR HEAD TO THE SIDE WHICH WE USE IF WE NEED TO READ OR FIND SOMETHING) ON ALL SIDES ARE NOT WORKING. i REALLY APPRECIATE IF YOU COULD PLS HELP WHAT COULD BE THE PROBLEM AND IF WE CAN FIX IT OURSELVES. THANK YOU SO MUCH
Dec 22, 2008 at 11:45 AM
  • 110,248 POSTS
Hi:
In the owner's manual, there will be a listing of the fuse locations and purpose. Check to see if he accidently moved the fuse, loostened it... As far as the rear wiper, check the fuse for it to. If it is good, you need to remove the inner rear panel and check to see if there is power to the motor.
Let me know what you find.
Mar 18, 2009 at 6:32 AM
