2004 Chrysler Pacifica advice
95,000 MILES • 6 CYL • FWD • AUTOMATIC
KSTWISTER67
I have a 04 Pacifica. It is starting to lunge a little when it idles. Also, it misses a little when it's at lower rpm's. I am thinking fuel filter and plugs, but I'm not sure. The engine light came on. If it is a filter, and I change it will the light turn off on it's own or does someone have to re-set it?
Aug 18, 2008 at 11:03 AM
TRAVELLER1861
Since no one seems to answer any posts with any meaningful advise, I thought I might take a stab at helping.
You need to get a Code Reader to determine why the Engine Light Came on. Once you know the code you can take the appropriate action.
You can get a real basic model from Harbor Freight Tools for around $40.
I use the 94168-1VGA and it does me just fine for what little auto repairs I do for friends & family.
Aug 24, 2008 at 12:48 AM
KSTWISTER67
Thanks.
Aug 24, 2008 at 2:41 PM
