Not shifting to reverse or neutral
200 MILES • 3.5L • 4 CYL • 2WD • AUTOMATIC
SHAWNICE KILLEBREW
It will shift to drive for about 30 seconds and the its drops when it does go in drive it will go up to about 10 to 15 miles nothing more.
Oct 16, 2019 at 11:55 PM
Good afternoon,
Is the check engine light on?
Did you check the fluid level?
From your description, it does not sound good. You may have internal issues requiring rebuilding the unit.
Oct 17, 2019 at 6:39 AM
