Chrysler Truck Scratch Cost
CHRYSLER
KATIE101
How much would it cost to repair a scratch thats not deep on my truck? Its about a foot long and i dont want to use scratch remover
Jul 27, 2006 at 3:34 AM
  • 110,251 POSTS
If it's not to the steel, most likely it will buff out for you. However, you will need polishing compouns.
As far as a body shop, there needs to be a break in the body line to end the new paint so you don't see it. If there isn't a bood break, they may want to repaint the entire panel. That could could cost up to 4 or 5 hundred dollars based on where you live.
Mar 20, 2009 at 9:50 AM
Suggested Repair
If the scratch has not reached the steel, it may buff out with polishing compound. A body shop needs a body-line break to blend new paint; otherwise the whole panel may need repainting, which could cost about $400 to $500 depending on location.
Conversation Summary
The owner of a Chrysler truck asked about the cost to repair a shallow scratch about a foot long and did not want to use scratch remover. The expert said it would likely buff out with polishing compound if it had not reached the steel. A body shop may need a body-line break to blend paint, or may repaint the entire panel for up to about $400 to $500 depending on location.
