2002 Chrysler Intrepid Dash Lights Flashing
CHRYSLER
MLRISPER
I have a 2002 Chrysler Interpid that has 99850 miles, and I have has several repairs done but now I am noticing my dashboard lights are flashing while I am driving. The lights go bright then back normal. Could you please let me know if I have a electrical problem or what could it be. I would appreciate your help :(
Apr 13, 2006 at 9:42 AM
LOSONE
  • 1,616 POSTS
The ground for the dash lights comes from the ground side of the cigar lighter. The 12V comes from a 4Amp or 7.5 amp fuse in the inside fuse panel. I suspect a bad ground Good luck
Apr 13, 2006 at 10:32 AM
Suggested Repair
Check the dash-light ground on the cigar lighter side and the 4A or 7.5A fuse in the interior fuse panel. A bad ground is the likely cause of the lights flashing bright then returning to normal.
Conversation Summary
The owner of a 2002 Chrysler Intrepid with about 99,850 miles reports dashboard lights flashing bright then returning to normal while driving and asks whether it is an electrical problem. The expert says dash-light ground comes from the cigar lighter ground side and 12V power comes from a 4A or 7.5A fuse in the interior fuse panel, and suspects a bad ground.
