Chrysler Center Trim Panel LED Out
CHRYSLER
WAZZ-13
How do you remove the center trim panel, the LED display does not work anymore , but I can't figure out how to get it out. It just went out althought it did come back on a couple times when it got really cold out. But now its nothing.
[img:a34f74dce1]http://www.2carpros.com/forum/automotive_pictures/68891_IM000668_3.jpg[/img:a34f74dce1]
ANY HELP WOULD BE GREATLY APPRICATED
THANKS
Wazz
Apr 15, 2007 at 10:29 AM
BOOTDOG
  • 665 POSTS
take a flat head screwdriver and gently pry around the outside edges and it should start to pop loose. that trim snaps in place, just be careful when removing.
Apr 15, 2007 at 11:49 AM
WAZZ-13
Thanks I will give it shot...
Wazz
Apr 16, 2007 at 3:21 AM
Suggested Repair
Gently pry around the outside edges of the center trim panel with a flat-head screwdriver so the snap clips release, taking care not to damage the trim.
Conversation Summary
The owner of a Chrysler asked how to remove the center trim panel after the LED display stopped working, noting it briefly returned in very cold weather. An expert said the trim snaps in place and can be released by carefully prying around the outside edges with a flat-head screwdriver. The owner said they would try that.
