car alarm 1992 chrysler imperial 6 cylinder
1992 CHRYSLER
STANTHEMAN
what is the ghost switch to disarm the alarm
Aug 13, 2007 at 7:29 PM
MIKE H R
  • CAR REPAIR CONTRIBUTOR
  • 3,094 POSTS
on aftermarket alarms there is a little switch or should i say button, it is usually hidden under the drivers side. it is usually black and is no bigger than a 1/8 of a inch. You will have to look for it. when you find it. before turning on the ignition press the button and hold while turning the ignition on. this should re set the alarm.
Aug 14, 2007 at 10:30 AM
