altenator
CHRYSLER
PYROKA
I have a 1990 pontiac sunbird and something is draining the battery. The altenator was checked at auto zone and they said it was working. The starter was going out and was replaced and all the wiring has been checked but the battery is still being drained. If the altenator is checking out ok what else could be draining the battery?
Jan 26, 2006 at 9:45 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Clarify whether the battery discharged while parked, during use or both, and provide any battery or charging-system test results already recorded.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
IHATEMYCAR
warped battery
Jan 27, 2006 at 12:38 AM
IHATEMYCAR
computer glyche also
Jan 27, 2006 at 12:40 AM
Discussion summary
altenator
The owner of a 1990 Pontiac Sunbird reported continued battery discharge. A parts store reportedly found the alternator working. The starter had been replaced and wiring checked, but the discharge problem remained.
Reported outcome: No confirmed cause or successful repair of the battery-discharge problem was reported.
The reported alternator test does not establish the cause of the discharge. Battery condition, the timing of the discharge and supporting test measurements were not supplied.
Read the original discussion
