97 chrysler only heats up when i move..
1997 CHRYSLER
FOREVERYOUNG88
how long would it take to replace the water pump..?? it only heats up when i press the gas pedal.. but when i let off the gass.. it gets cold.. wut is the problem.. and if i need to replace the water pump.. how long would it take to replace it??
Mar 3, 2006 at 2:37 AM
JPAM
  • 307 POSTS
please send make:chryler model: ?? year:97 and engine size?? milage to would help to get better answer... thanks Jess S.
Mar 3, 2006 at 7:16 AM
PEPPERMRJ
  • 1,158 POSTS
Don't rule out low coolant level or a thermostat that is stuck open.
Good luck. :)
Mar 3, 2006 at 7:49 AM
