2004 Other Chrysler Models Possible problem with trans.
2004 CHRYSLER
41,000 MILES • 6 CYL • 2WD • AUTOMATIC
SLYONE109
I had my car out in the cold for 8 hours while working, and when I went to leave I put it into Drive, and it was as if it was in Nuetral. After a few shifts to park and back to drive I was able to drive. I have also noticed a leak of some sort under the right almost center in very front of the car. It is pinkish in color. Is this a major problem? Could it just be the cold weather? It is below 0 tonite.
Jan 19, 2008 at 4:30 PM
JRT
  • 27 POSTS
HAVE YOU CHECKED THE TRANS OIL LEVEL?
FILL IT TO THE PROPER LEVEL AND YOU SHOULD BE ABLE TO DRIVE IT TO GET IT REPAIRED.
SOUNDS LIKE THE TRANSAXLE SHAFT BOOT IS LEAKING.
Jan 22, 2008 at 3:35 PM
